Problems opening Rhino files & Enscape crash
Hi There,
since a few weeks (guess after the latest Rhino 7 Update), I have major problems opening Rhino files. Either they wont open or take a lot of time. And then with the small files that do open, Enscape crashed immediately after opening. Had contact with enscape and did all I could, but problem remains.
Guess that the issue might be with the latest update of Rhino vs my not too young computer.
Previously all worked super, with big Rhino files & combined with Enscape usage.
any tips?
maybe a possibility to download a previous version of Rhino 7?
Many thanks in advance!
Can you find a RhinoDotNetCrash.txt on your desktop?
hi there,
no the .txt is not there. But Rhino crashing is also not the issue. The programme remains alive, but files just wont open. The crashing part is for Enscape, and most of the times when this happens, Rhino remains working
Hi Sjoerd, Can you provide your SystemInfo by running the command via command line and paste here? Thanks
In the Rhino Command Line please run the SystemInfo command.
Rhino 7 SR21 2022-7-27 (Rhino 7, 7.21.22208.13001, Git hash:master @ c31aea87137a5d0de449338a7ef6856f49dd4797)
License type: Commercial, build 2022-07-27
License details: Stand-Alone
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 7.9Gb)
Computer platform: DESKTOP
Primary display and OpenGL: Radeon Pro 580 (AMD) Memory: 8GB, Driver date: 11-11-2021 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 20.45.40.15 27.20.14540.15002
> Accelerated graphics device with 8 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 11-11-2021
Driver Version: 27.20.14540.15002
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\Sjoerd Zonderland\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22102.1509
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\BlockEdit.rhp “BlockEdit” 7.21.22208.13001
Thanks, can you disable the Vray plugin while troubleshooting (restart Rhino after disabling via Rhino Options>Plug-Ins)
There is an update to your driver https://www.amd.com/en/support/graphics/radeon-500-series/radeon-rx-500-series/radeon-rx-580
Hi Japhy,
thanks for your help and sorry for the belated reply: have been ping-ponging the last days with AMD (Graphic driver) to discover any problems. This is the conclusion:
Thank you for your feedback and for performing the Clean Uninstall.
Your system now has the latest version of the Bootcamp drivers installed. The date of the EXE can be misleading. The EXE file is only the executing file and gets the data/drivers to be installed from the folders, as you can see from your screenshot the creation date of the folders is from 2022.
This means that the latest Bootcamp drivers have been successfully installed on your system. There is no newer version of the Bootcamp drivers for your Mac.
Although we provide the download of the Bootcamp drivers on our website, the driver is developed by Apple for your Mac hardware that can also run Windows (Bootcamp). As it is not a fully-fledged Windows version, we are unfortunately unable to help you further, except to carry out a clean installation of the current drivers with you, which we have done.
If you experience any further problems and are unable to use your software such as Enscape for Rhino, there is no way around contacting Apple and/or Enscape support.
If you have any further questions, please do not hesitate to contact us.
With kind regards
Your AMD Customer Service
still encountering the same problems,
and bigger Rhino files won’t open at all anymore…
any other tips or time to throw this imac out of the window?
would be a shame though…
Can you post your updated systeminfo please. Thanks.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\NamedPositions.rhp “Named Position”
I see, just because the installer is newer it doesn’t contain a newer driver.
Lets try your roll back idea. Sending you the previous release of Rhino, let me know if there’s a particular one that you want to try.
