Rhino crashes before opening a file
Hey. My rhino just wont open some files that i previously worked on without any problem. any idea why that might be ? the file opens, but before i can see anything, it just closes…i tried safe mode…same issue. thank you. (i am using a dell xps15) and i have the latest version of rhino. i just updated thinking it would solve the issue but same thing keeps happening.
Hi Luiza - please send an example file to tech@mcneel.com, with a lin k back here in your comments.
hey this is a link to the file i really need…
Hello- you have Enscape and Vray user data in this file - are both of those plug-ins up to date? Does the file open if you disable these completely in Options > Plug-ins and then close and reopen Rhino? The file opens here.
it did work when i disabled the plug ins ! thank you so much. what will i do when i want to render ?
hit up the plugin makers to see if there is an update or hit their tech support for help with their products.
