Raytracing meshes with vertex colors
Raytracing vertex colors is possible.
The vertex color material is currently still a hidden one so you need to run first once the command TestShowPrivateContent. You should find the Cycles vertex color material now as an option to create when making a new material.
Assign that to your object.
All meshes are triangulated. You probably need to explain with images how you think blending should be better.
