I’m wondering if there is any method, extant or planned, for rendering mesh colors in Cycles?
Anyone have a method for getting it to work?
Thanks
Thanks
There is a material behind the TestShowPrivateContent that, when applied, renders vertex colors.
Hi Nathan thanks for the quick reply,
Not sure what i’m looking for is that in one of the material folders? Is that a command?
thanks for the help
Type the command TestShowPrivateContent. This will show ‘secret’ Cycles/Raytraced materials. You should add a material of type Cycles VertexColor, and apply that to your object.
Here a quick demo with a vertex-painted Suzanne, exported from Blender.
If this still doesn’t work, could you please share your 3dm with baked skeleton model with me? If you don’t want to share it publicly you can use rhino3d.com/upload to share privately with me. Use nathan@mcneel.com as the recipient.
/Nathan
thanks nathan, here it isclimber_skeleton_forces.3dm (1.3 MB)
Hi Nathan,
Still not working on my end.
I thought maybe I’d update to latest version, now running BETA 6.0.17325.8311, 11/21/2017
Another curve ball is I can’t seem to be able to select Rhino Cycles as current Renderer anymore, its not listed under available renderers,
thanks again for your help
zach
Cycles for Rhino (CfR) indeed is no longer available as current renderer, but the very same render engine is Raytraced. This is because CfR won’t be part of the final v6, and we thought it better to not have it linger around in the BETA confusing people.
I’ll update to latest BETA as well, this rendering at least works in my local build.
Hey,
Ok cool, not sure why it continues not to work in my raytraced view, it is rendering the vertex colors in rendered view and with rhino renderer but not at all in raytraced, this is my systeminfo if it helps
Rhino 6 SR0 2017-11-21 (Rhino WIP, 6.0.17325.8311
Windows 8.1 (Physical RAM: 16Gb)
GeForce GT 750M/PCIe/SSE2 (OpenGL ver:4.5.0 NVIDIA 368.81)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 7-10-2016
Driver Version: 10.18.13.6881
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino BETA\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino BETA\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino BETA\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino BETA\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino BETA\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino BETA\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino BETA\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino BETA\Plug-ins\RhinoRender.rhp “Rhino Render”
C:\Program Files\Rhino BETA\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino BETA\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino BETA\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino BETA\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino BETA\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino BETA\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
C:\Program Files\Rhino BETA\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino BETA\Plug-ins\Displacement.rhp “Displacement”
updated and re-started, still no luck, anything else i might try? not mission critical to be able to render them but would save a boatload of work
Not sure what is going on, but when I start Raytraced not all meshes render properly, but if I select all objetcs and assign the material again while Raytraced is running things look much better. Maybe that will work for you for now?
If that also doesn’t work, can you still try with CPU as the render device? Change it through Tools > Options > Cycles before switching to Raytraced.
Tried it with CPU and still no luck, it seems as though raytrace isnt rendering any materials at all now
Not sure what to suggest at this point, perhaps, as a shot in the dark, try repairing your Rhino BETA install?
Or maybe before you try that, can you try importing attached FBX file, and assign the mesh a Vertex Color material?
vertexpainted.zip (66.5 KB)
Hi Nathanletwory,
Can you -viewcapturetofile out of raytraced view? I’m attempting this but getting all black jpeg’s,
also will Cycles be available for purchase as a rendering engine after release?
zach
The ViewCaptureTo* commands should work. If you use a resolution different from the viewport you should be getting a rendering done by the modal renderer (you’ll get a progress bar dialog), which is the very same mechanism as the render window rendering conducted by Cycles.
I’ll ask @andy and @marika if they can capture fine, they both have a GT 750M in our office IIRC.
In the meantime you could try forcing Cycles/Raytraced to not using OpenGL: open Tools»Options»Advanced and type UseDrawOpenGl. Toggle it so it says false. Then switch a viewport to Raytraced and see if your regular ViewCaptureToFile works better.
Regarding Cycles availability for purchase I doubt it. It won’t be in V6, but the next WIP should be available a or around the release of V6, in which you will have access to CfR without additional cost.
/Nathan
Right on I’ll give that a shot,
Thanks for your help Nathan,
Zach
No problem - I don’t like it when Raytraced doesn’t work, so I’ll try my best to find a solution!
Hey how can I render vertex colors after all the “recent” changes to the rhino rendered viewport/cycles ?
