Radius Dimension Mirrored in Layout detail
I just noticed a little bug. I used TiltView (90 degree, left) in a layout detail for a TopView. The radial dimension font got strangely mirrored. Normal dimension was fine.
edit:
wanted to upload a screenshot but can’t. get an error, always happens with firefox. hope this gets fixed too.
mirrored dimension
2nd edit:
quick google search reveald that the image upload failing was due to a plugin in firefox. works now. obviously that doesn’t solve the rhino bug.
@mcneel team,
is this reproduceable?
hello, i would like to get support from mcneel regarding this bug.
in the named annotation style that dimension belongs to, Is the option for “Text reads forward when viewed from behind” checked?
Options > Annotation Styles > [style name] > Font
That option was checked. After I unchecked it, the dimension text isn’t mirrored anymore. That’s it, thank you.
I had looked for an option like this in the properties panel but didn’t expect to find a solution in the options menu.
