I don’t quite understand a lot of things about the new text stuff in R6 but this one is causing me issues. Text is mirroring when I rotate the view and I don’t know how to stop it. I have multiple texts in the file and I can’t worry about where my camera angle is to make text view correct.
Here’s two images overlayed into one image showing how a slight rotate in the view casuses that mirroring effect.
Will you rotate the viewport around so the camera is close to the view I showed? It looks fine from the left and right but right where the camera is parallel to the label it turns over…
Ok I don’t know whats happening. It works by turning that off. I would have sworn I had it turned off to begin with. I’m gonna start another thread on some different text probs. Thanks for your time I appreciate it.
Hi Jeremy, Asterisk, Jason and all,
This just came on my radar here.
I would like to get this logged as a bug.
Could someone please provide me with a small file and a procedure to duplicate the issue? Also include the version of Rhino you are using.
Sorry about the issue.
Thank you for your help.
Sincerely,
Mary Ann Fugier
Robert McNeel Technical Support
It clearly does not make sense.
So far I can not recreate the reversal of the text as you showed.
Is that wall vertical and coplanar with the viewport CPlane when you created the dimensioons?
Did you create them separately, or all at one time using the continue option?
This was a while ago and I didn’t keep my original experiments, but here is a variant of the OP’s file posted above. Only change has been to zoom in. If you use mouse right button to rotate the view right and left you should see the text flip, then come back to face forward.
I just tried this in 6 SR 17 (6.17.19218.13231, 06/08/2019).
In our tests here, it seems like the mirror issue is better with sr18.
With 6.18, we can open your file and it is not mirrored on our Rhino.
Here is your video.
Here is mine.
We would like you to try the daily build of Rhino called “trunk” .
This is how, you can get the daily trunk build:
Start Rhino
Run TestEnableDailyBuilds
Go to Options->Updates and Statistics
In the " Update Frequency " dropdown, select " Trunk (Daily )"
Then click the " Check Now …" link just below the dropdown…
That should take you to the latest version of Rhino.
Please download and install it.
Test and let us know if that helps with the annotation text issue.
At some point, you will want to return to the service releasecandidate or the service release . This way you can let us know if this helps as soon as possible.
Sincerely,
Max Fugier
McNeel Technical Support and Training
Seattle, WA
