hey,
r8 is not opening any more after crashing the whole system.
getting this error message:
puh,
Benjamin
hey,
puh,
Benjamin
What do you mean by “crashing the whole system?”
That appears to be the ‘server is busy…’ message that pops up usually when you are trying to open up a new Rhino session while another is really busy working on something.
Jim,
crashing the whole system means that the machine was frozen and I had to hard reboot it again.
anyway, I cant open rhino anmore.
But that message is telling you there is a Rhino open, doing something.
Can you open Rhino in Safe Mode and run SystemInfo in the command line?
To run via safe mode search for Rhino 8 in Safe Mode in the Windows run
Japhy,
Rhino 8 SR6 2024-4-2 (Rhino 8, 8.6.24093.11001, Git hash:master @ de3127ef7b7fd6e4c2fef07a9a1bc10c8e1942a3)
License type: Kommerziell, build 2024-04-02
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 SUPER (NVidia) Memory: 8GB, Driver date: 4-2-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.12
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-2-2024
Driver Version: 31.0.15.5212
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24093.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24093.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24093.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24093.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24093.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24093.11001
after checking for updates getting the error message above again.
Thanks, SystemInfo looks ok. This is not from safe mode, so you are able to open normally sometimes? Is there a particular file involved?
Not seeing any crash reports, are you given an opportunity to save one?
ok, this was my mistake. but if i am following your instructions this is all i get. the search resulkts for safe are just showing rhino 7 safe mode.
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce RTX 2080 SUPER (NVidia) Memory: 8GB, Driver date: 4-2-2024 (M-D-Y). OpenGL Ver: (null)
OpenGL Settings
Safe mode: On
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 8x
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: n/a
I’m not sure what is going on here.
What steps do you take to repeat the crash?
thank you Lucio, this is not working, I tried that before. I will try to setup a new installation of rhino. that should work.
Is this happening after upgrading to 8.6?
Have you tried to install Service Release Candidate?
Lucio,
yes, I have 8.6 installed due to the changes of the “use model scale” for line types.
unfortunatly I cant open rhino any more. when I open it with the safe command from win search it opens, but I am not able to da anything else > error.
