I have this issue since R6. Some italic text don’t show as italic when in Rhino PDF. However, I tested several fonts and found some fonts do work. But now it seems all fonts are failing in R7. Can someone explain what’s going on?
Hi Hogan - Please run the SystemInfo command in Rhino and copy/paste the results here.
If you can export some of that bad text to a new file and post it here, that would be helpful.
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 3-25-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 465.89
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-25-2021
Driver Version: 27.21.14.6589
Z-Buffer depth: 24 bits
Total Video Memory: 10 GB
C:\Users\hogan\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21089.1448
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Users\hogan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.1\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.1.0
C:\Users\hogan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
Thanks I see that here as well. It seems to be that font, and only in vector output - if I change some characters to Arial, the italic is respected on those in vector.
