Have arctic mode tiling artifacts when using ViewCaptureToFile with resolutions higher than viewport size (see attached picture).
Tried adding a rectangle as ground plane and enabling the ground plane option, without success. Thought the arctic tiling problems have been fixed three years ago. Any ideas?
Cheers,
David
John_Brock
(John Brock)
October 19, 2020, 8:24pm
2
I’m not seeing that here on my V7.
Can you please post your file and the resolution you’re trying to capture?
Resolution is 6821x2636 pixel, using it together with a wallpaper.
Thanks for diving into this.
Cheers,
David
arctic_tiling_problem.3dm (2.0 MB)
John_Brock
(John Brock)
October 19, 2020, 8:44pm
4
I was able to repeat it with your file at that resolution:
https://mcneel.myjetbrains.com/youtrack/issue/RH-61061
Ok, hoping for a fix soon.
Cheers,
David
Hi @lemberski ,
The fix is already in Rhino 6 Release Candidate 31. The fix should appear in Rhino BETA sometime next week.
Hey McNeel team,
fixed in release 7.0.20295.18003.
Thanks!
