eobet
(eobet)
July 11, 2021, 2:48pm
1
I’m hoping this is very outdated:
https://grabcad.com/tutorials/how-do-i-add-thickness-to-a-polyline-in-rhinoceros-3d
At the same time, I only found a thread from 2014 about this here…
Is there a more recent way of changing line widths in the viewport?
The “print width” object property setting doesn’t seem to affect the viewport and that’s the only width I see.
kev.r
(Kevin)
July 11, 2021, 3:25pm
2
If you run the _PrintDisplay command you will be able to see the effects of changing the Print Width object property.
-Kevin
eobet
(eobet)
September 24, 2021, 8:01am
4
Is there a way to set this to permanently On for a Display Mode?
The setting is sadly not where I expected it to be:
wim
(Wim Dekeyser)
September 26, 2021, 7:43pm
5
Hi Robert -
That is not a display mode property, no.
Screen vs model units curve widths is something that is being looked at for Rhino 8 but it’s too early to know when that feature will be available.
eobet
(eobet)
September 27, 2021, 1:26pm
6
I just discovered this:
This would be perfectly fine, but unfortunately I don’t see how I can change the behavior of this toggle to use Color=Display…
Testwirethicknessscale makes all lines thicker.
