Q: detail in layout with different scales but only one dimension?
Hi…,
my customer wants to create some layout details with different scales 1:50, 1:10, and 1:1.
Is there a way to dimension the part with one dimension style for all scales, so that the dimensions look right (same equal line spaceing) in all details? (I’ve tried it, but I think not).
Detailsansichten_mit_verschiedenen_Massstaeben.3dm (869.2 KB)
Any ideas?
Thanks
Michael
www.flexiCAD.com
Hi Michael - I think just make the details in the layout space - does that do what you need?
Hi Pascal,
I don’t understand, do you have an example?
Do you mean to dimension the parts on the layout and then use different dimension styles?
Thanks
Michael
www.flexiCAD.com
Hi Michael - maybe I’m misunderstanding - in the attached file, I placed all the red dims in layout, not model space - does that make sense with what you need?
Detailsansichten_mit_verschiedenen_Massstaeben_PG.3dm (879.3 KB)
Hi Pascal,
that’s it, great. I wasn’t aware that Rhino recognizes the correct picked size in layout space. I thought it would always use the current distance on the layout paper.
Thank you again
Michael
www.flexiCAD.com
