Putting tolerances in Drawing inside Rhino WIN
Hey gang,
I’m making a 2D Drawing in Rhino and having trouble putting in tolerances.
Like 10 +0.005 -0.003
I double click on the text and I can input the text, but making the tolerance in smaller text is what I can’t do.
Any good way to put tolerances in?
The same size text makes the drawing
quite confusing…
The only way I have found is to make an extra text, independent from the dimension.
In V6 a lot is done about dimensioning, including tolerance handling.
You can try V6, go to the Serengeti section for more details.
-C-H-A-R-L-E-S-
Oh… I was afraid of that answer. doing that now. adding text on it’s own.
I’ll check up on V6 after finishing up this one…
Thanks!
