Hi @lowell,
a Rhino 6 customer reported, that the tolerances are missing in this sectional view.
What to check?
Thank you
Michael
www.flexiCAD.com
Hi @lowell,
What to check?
Thank you
Michael
www.flexiCAD.com
Hi Micheal,
It looks like the <> which represents the value was overwritten with 200 so you just need to retype <> in the edit box.
Alain
Hi Alain,
sorry, my question seams to be wrong. The customer wants to change the length value manually and keep the tolerances.
Thank you
Michael
Ok, but the tolerance should display even in this case.
I can’t find any argument against that.
In this case, the part is divided.
The component is longer than shown in the drawing - therefore the dimensioning must be overwritten manually.
This is necessary to bring the part (sometimes up to 1500 long) in a meaningful size to the drawing.
Ok, I see why you’d want to do that. I’ll let @lowell chime in.
I see that tolerance display doesn’t work when the natural dimension value is replaced with other text.
https://mcneel.myjetbrains.com/youtrack/issue/RH-44973
Lowell
