Add allowed deviations/uncertainties to dimensions in Rhino
So I’m basically trying to create a technical drawing in Rhino and I’m doing fine so far. But I’m currently trying to define a dimension including allowable deviations in accuracy (see image):
Is something like this easily done? Or can I only specify the dimension of a line/distance and will I have to manually add details like this?
I don’t think Rhino supports the comma, but yes, Rhino dimension styles do support Tolerances:
https://wiki.mcneel.com/rhino/faqtolerances
To clarify, dim styles can be edited in:
Options -> Document Properties -> Annotation -> Dimensions
