Properties - Layout scroll too short?
I noticed after the recent update, the layer list dropdown became very short in Properties. There are only 5 layers, and it has to be scrolled to get to the bottom 5th. I wasn’t like this before, and it gets quite annoying with even normal amount of layers, certainly a lot more than 5.
Version 8 SR15
(8.15.25019.13001, 2025-01-19)
I’m not seeing that here.
Please provide the full SystemInfo data.
Rhino 8 SR15 2025-1-19 (Rhino 8, 8.15.25019.13001, Git hash:master @ 74164bdf5469c2f269746857c54b8c44b74c7b24)
License type: Commercial, build 2025-01-19
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 4090 Laptop GPU (NVidia) Memory: 16GB, Driver date: 12-3-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.36
- Secondary monitor attached to adapter port #2
Primary OpenGL: NVIDIA GeForce RTX 4090 Laptop GPU (NVidia) Memory: 16GB, Driver date: 12-3-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.36
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-3-2024
Driver Version: 32.0.15.6636
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Users\a-lawrence\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.15.25019.13001
C:\Users\lsong\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.15.25019.13001
C:\Program Files\Rhino 8\System\netcore\export_PDF.rhp “PDF Export” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.15.25019.13001
What happens when you disconnect the external monitors and run Rhino on the laptop’s display?
The behavior didn’t change with external monitors unhooked.
I think I found why I got confused. Other files show longer drop down for layer, and it always stops short right before the last layer.
Since the file in question had 5 layers, the drop down only showed 4 layers, which made me confused why the drop down was so short. If there are 15 layers, the drop down will show 14 layers. You will have to scroll down to see the last 15th layer.
Is there a reason for such behavior? Certainly no reason not to show the whole 5 layers or 15 layers in drop down?
