Properties panel won't stay where I want it to be
I have a user interface issue with Rhino, could somebody help me ?
I want to put the properties panel here, below the other tabs :
But it never remembers this position, everytime I reopen Rhino I get this :
system info:
Rhino 7 SR26 2023-1-9 (Rhino 7, 7.26.23009.07001, Git hash:master @ 92abcf7c453c78a236526390d91d0ac1f6779143)
License type: Commercial, build 2023-01-09
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 31Gb)
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 9-28-2022 (M-D-Y).
> Integrated accelerated graphics device with 3 adapter port(s)
- Windows Main Display attached to adapter port 1
Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 5-5-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.78
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-5-2022
Driver Version: 30.0.15.1278
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\NamedPositions.rhp “Named Position”
Hi Felix -
Yes, that’s one of those things. Sometimes it helps when you close all instances of Rhino, start a Rhino session as Administrator, put the panels in place and then close and restart Rhino in the usual manner.
The UI foundation is rewritten in Rhino 8, and, hopefully, this behavior goes away…
Hi Wim,
Thank you for the advice. It suddenly worked for no apparent reason before I saw your reply… I don’t know what I did, at some point when I opened files it just worked.
Thanks anyway !
