Layer drop down window out of reach
In the past week I have begun to be able to use the bottom half of my “Layer” drop down window. I have tried restarting, minimizing the program window and moving the drop down window as well.
Hi John - are you using more than one screen?
Yes, I have two screens at work off a desk top and three at home when I use my laptop.
Hi John - just as a test - disconnect a display and only keep the primary - does that work better?
It did not help, I also tried moving the Properties Object window," undock it from the Layers window", and the drop down window did move up some, but not enough.
Hi John - let me make sure I actually understand what the problem is - is it that on the object properties dropdown list of available layers, the displayed list is truncated and there is no scrollbar to get at the bottom of the list ?
Can you please run SystemInfo in Rhino and copy/paste the results here?
Yes, that is correct.
Rhino 8 SR7 2024-5-17 (Rhino 8, 8.7.24138.15431, Git hash:master @ 03702f889bdef32626af4bca510b5e8a85666d38)
License type: Commercial, build 2024-05-17
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P2200 (NVidia) Memory: 5GB, Driver date: 1-28-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.65
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-28-2022
Driver Version: 30.0.15.1165
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\export_GHS.rhp “General Hydrostatics (GHS) Export”
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24138.15431
Hi John - this is somewhat a shot in the dark but just to eliminate the possibility, and because it is a good idea anyway, please update your gpu driver from the Nvidia website - yours are a couple of years old.
Looks like the update did not take.
Here is the SystemInfo from the update.
.NET 7.0.0
Primary display and OpenGL: NVIDIA Quadro P2200 (NVidia) Memory: 5GB, Driver date: 5-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.55
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 5-23-2024
Driver Version: 31.0.15.5255
Was:
Now:
So it looks like the Nvidia driver update “took”.
However Rhino itself is still:
You might want to update Rhino to the latest Release Candidate.
Courtesy of Nathan:
The update still has not resolve the issue. Here is the SystemInfo from the update.
Rhino 8 SR9 2024-6-11 (Rhino 8, 8.9.24163.15301, Git hash:master @ 17c7f1c7c05ff0e0b5b12288d13a911b1f0767b4)
License type: Commercial, build 2024-06-11
.NET 7.0.0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24163.15301
