i have a model here that has been throwing me fits. I can’t do subobject selection on the faces or edge of this object in v7 but when i copy it over to v6 i don’t have problems.
kyle helped me out with a technique to fix the surfaces in another thread but i came in today, did some edits, joined them back up into a solid and am unable to do subobject selection.
he originally thought it was the source geometry possibly being from other software but i opened all my source files from this company and they all originated from rhino.
i have been taking the model, exporting it as igs, importing into solidworks, editing, exporting out as igs, go back to rhino. i thought maybe solidworks was wonking the file, but i just exported from solidworks, opened in v7, doesn’t work, copied model over to v6 and it’s fine. so it’s not SWX i assume.
i just noticed that i can cross window select and get subobjects.
i just took my v7 file, saved it out as v6, opened in v6, subobject select ok, opened the v6 file in v7, subobject works, saved that file out as v7, reopened that v7 file, subobject selection doesn’t work. so something must be happening in the v7 save?
hm - so the errors.3dm file … if you open that and isolate one surface, you cannot Ctrl-Shift click and edge and see the entire loop selected? That is (I thought anyway) part of the problem - you don’t get the obvious individual edges… the script was meant to fix that - it splits up that loop into the obvious edges.
But, if you cannot get the Ctrl-Shift to select at all… then I am back to square 1…
I just want to be sure what this means: ctrl-shift-click does not select any subobject (edges, faces in a brep for instance) at all? Or the edge is selecting but has reverted to the full edge loop? or?
And does this work on other objects in the same file - for instance, add a box…
It probably has nothing to do with this problem, but I notice your Nvidia driver is over two years old. I have the impression from the forum that that’s way too old for Rhino v7.
