Problems with Layer Window Rhino 8
I have recently been having an issue with Rhino 8. When I try to change the color of a layer and am directed into the color picker dialog box, if for some reason I take a moment too long and the layer window behind automatically re-docks intself to the side panel of may screen before I exit the color picker dialog box, Rhino freezes. Any thoughts on this?
Thanks,
Caleb
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13001, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Commercial, build 2024-03-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.17
Computer platform: LAPTOP - Plugged in [92% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 5-5-2020 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 3000 (NVidia) Memory: 6GB, Driver date: 11-23-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 527.27
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-23-2022
Driver Version: 31.0.15.2727
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24072.13001
So far, I can’t duplicate that.
I am running V8 SR7, and I have current display drivers loaded.
I would update Rhino to the current service release candidate SR6, and update your display drivers.
Any better?
Thanks John. I updated Rhino and my Intel GPU as recommended - I had already updated my Nvidia GPU prior to the post. It seems better, but if I try to change the layer print color, and let the layer manager window close behind the color picker dialog box, Rhino hangs up.
you are running a hybrid machine-
have you done this set up?
also always run rhino plugged in to wall power- (which you are doing)
Thanks Kyle - yes I had gone through this process after seeing some of your replies to similar posts.
give us a call so we can take a peek at what is happening-
feels like something simple that is happening, as I am running a very similar set up and can’t reproduce this-
206-545-6877
whoever is on phones when you call can help out-
