Problems importing Autocad file
I’m trying to import a basic file created in autocad and am running into some issues. I’ve only drawn regular lines in the file and then saved the autocad file down to 2007. When I go to import rhino just says that there was an error importing. Is there something else that I need to do to the autocad file before exporting it?
Drawing1.4.dxf (228.9 KB)
i left it running for a while after i selected the file for importing before i clicked ok, but i dont believe this was the issue… it opens without any errors, not sure why you cant open it. i am using the latest wip maybe thats the reason.
Drawing1.4.3dm (2.9 MB)
Downloading the latest WIP fixed it. Strange.
Thanks!
having the same issue…
tried import w/ acad18, acad13 & acad2000 & Copy/Paste btwn programs & Open in Rhino & .dxf
(Rhino is up to date & Autocad LT for Mac is up to date via subscription)
not sure what to do…any suggestions?
BlockquoteCommand: _Import
Error converting file.
Error importing file “/Users/adamchristie/Desktop/new block-2.dwg”.
Command: _Import
Opened AutoCAD file version Unknown.
Error importing file “/Users/adamc/Desktop/new block-2.dwg”.
Command: _Import
Opened AutoCAD file version AutoCAD 2000.
Command: '_Paste
Command: /var/folders/8x/blkbrb8n2rz9g8h_jbnt4dmc0000gn/T/A$C74C225CB.DWG
Unknown command: /var/folders/8x/blkbrb8n2rz9g8h_jbnt4dmc0000gn/T/A$C74C225CB.DWG
Command: _Import
Command: _Import
Error importing file “/Users/adamchristie/Desktop/new block-2.dxf”.
Blockquote
new block-2.dwg (217.6 KB)
after a bunch of hard reboots, it’s working again…
instead of ‘import’, just simple ‘open’ the file with rhino, :slight_smile:
I am having the same problem, what can I do?
I’m using Rhino 5 and AutoCad 2018. I’ve saved the AutoCad file in many different ways… I don’t understand it. Heeelp!
(How can I download the latest WIP to see if it works?)
Please see this thread:
That said, can you post a file that is giving you troubles and describe your workflow and possible error messages?
