Problem with output color
Version: 7.13.21348.13001, 2021-12-14
The file attached has only one object: a trimmed surface.
The surface is located in Layer 01 which is red.
Display color is “By Layer”
Print color is “By Layer”
In the viewport, I see the red surface with red contour as expected.
Problem:
On the Print Setup page the surface is no color (white).
I only see the red contour.
(If I change Print Color, the contour changes accordingly)
This is the case no matter which output device I select (even Rhino PDF).
The only exception is Image file, which show (and print) the red surface correctly.
What do I miss?
Best regards,
Niels Foldager
Dump.3dm (142.3 KB)
i think you have to change “Output Type” to “raster-output” in the pdf to get the desired shaded appearance of the triangle.
for 2d stuff - i think hatches are exported as filled vector-graphics…
not tested - let this forum know if this is already enough help.
kind regards -tom
That is the solution to my problem. Thank you very much.
If I change Print color to, say, blue, the print has a red surface with blue contour.
Is that how it is supposed to be?
Best regards,
Niels
