it happens in technical display mode, did not try others such as wireframe.
in layout colors are displayed as expected.
when printed not really.
seems to work fine with wireframe instead of technical.
Now i found a superbug.
Just turning some layer on and off makes colors in pdf totally absurd.
Printdisplay on print color on:
looks ok in layout
just turning some layer on makes it go crazy:
looks good in layout
To be honest these are super crazy bugs for SR13!
I am sending file to support and expect fasttracked fixing. Thank you
hi @Juan_Gallo yes, pls upload a file that shows the issue here
the link does not work i sent it to support@mcneel.com
Thanks, I’m currently looking
Bug shows in Vector but not in raster.
Weird, if you cut and paste those dashed lines, the issue is no longer there.
BringToFront brings the problem back, SendToBack on those curves also ‘solves’ it.
RH-84499 Vector print: objects get wrong color
RH-84499 is fixed in Rhino 8 Service Release 13
Hi Ivan -
You didn’t attach a file, but I suppose there are curves in that scene?
At any rate, I’ve filed RH-85167 Print: Color of Block Objects is Not Print Color
Without a file from you, I can’t tell if that is the same issue…
you got it right. please make this high priority i cant finish my drawings since it is solely dependent on this. the thing is it displays correctly in layout but not in print preview nor pdf
