PDF Output Issues
I am trying to create an illustration. In the attached I have a file with curves created using Make2d. I have then used Hatch to fill in some areas.
(1) When I create a PDF and the color setting is PRINT COLOR, the lines do not show up. If I change to DISPLAY COLOR, the lines show up. The print and display colors are the same.
(2) The edges of the hatch/curves are wavy in the PDF, giving a 3D effect to this 2d drawing. No such waviness shows up in the Rhino file.
Suggestsions?
Display Color.pdf (38.3 KB) Print Color.pdf (38.3 KB) 3d Deck Elevations Perspective.3dm (3.8 MB)
