try the file ctrl p rhino pdf and alternate between vector and raster
you will see there is different hatch color (grey shade different) between those two
navrh_most_Poprad.3dm (812.5 KB)
Hi Ivan - this seems to be related to being in Rendered display mode - print from wireframe or shaded for now, looks like the way out.
yes but hatches should not be affected by the mode right? is it bug or feature?
I am assuming it is a bug… I was just hoping to get you a workable solution for now.
RH-68381 Print: hatch color changes in rendered mode
my solution was to change color to paler one i did not experiment with different modes even though i suspected it to be a reason
