Hello, I have a problem with working with external drive - WD My cloud home.
The first problem is that I cannot correctly open any 3dm file directly from the drive. I have to copy it into the PC and then work in it. When I try to open it directly from the drive it will crash immediately.
The next problem is when I am trying to use some textures, picture frames or importing different files to Rhino directly form the drive. It stops working or sometimes it is working but you can pan, move, rotate and that is all. You cannot enter any command.
The last problem is saving. It is possible to save but anyway the rhino window will freeze and then I have to end the task.
I would like to kindly ask you if you had different problem or know how to solve it.
I think drive is not a problem because Photoshop, Marvelous designer or different sw are working just fine.
Thank you very much.
