Site object (toposolid)
Hi @Japhy,
I have noticed that toposurface components are automatically read as an old component in Revit 2024. Fortunately, those components are still working from the old RIR definition.
I understand that Revit 2024 above those not support toposurface, however, there is not much opportunities to create toposolid using the points in RIR for Revit 2024 as opposed to the RIR for Reivt 2023 below. Add toposolid component accept only the planar boundary as an input… I reckon this is the limitation of RevitAPI 2024.
Would you recomend us to keep using old components to create topography and generate toposolid from the toposurface? would there be any plan to add “Generate Toposolid” component in the near future?
Thanks in advance.
The TopoSolid is essentially a floor now, you can use the Host Shape component to add points.
Hi @Japhy,
awesome! yes… that works perfectly!
thanks always for your support.
