Problem Upload model
Hi wevery one, I have a problem uploading one particular model, I uploaded it on friday, but today I deleted it and I wanted to upload again, I don’t understand, because another model more complex work without problem, this is the error.
When I delete the Download Export component it works.
I have an account with Karamba licence, but I didn’t use it in this model.
Thanks for all your help.
Best regards.
PD: I can send the model but it will be private.
You can send me the model by private message so I can investigate the issue.
Hi Mathieu, thanks for your support, I’ll send you the model by private.
Thanks a lot.
We could reproduce the issue and we are investigating it. It only happens on the system you are using for Karamba, not on the shared one, so it might just be a plugin or Rhino service release versioning issue.
Hi Mathieu, thanks for all your support.
@acevedodavid396 This issue should be resolved, please try to upload your file again and let me know if you are still experiencing issues.
Hi Mathieu, perfect.
Yes, the problem has already been solved.
