RiR Floor Arc problem.gh (12.1 KB)
Hello McNeel Forum,
I’m having trouble creating floors using boundary curves made of arcs. Could someone take a look at the attached screenshot and script?
Thank you!
Thank you!
Thank you Japhy!
Any guidance in oder to continue working with arcs?
Revit does like Arcs and Lines over Curves typically, per the previous message I would expect these to work.
What version of Rhino & Revit are you using? Metric or Imperial?
Dear Japhy,
I have tried to recreate the arcs within the tolerances without success.
Those are my versions:
Rhino 8 SR8 2024-6-11 (Rhino 8, 8.8.24163.12481)
Revit 2023.1 Metric.
Thanks!
Hi @jelis_perez,
There is a fix for this issue on the daily build (v1.23) and will be also available on 1.22 next Tuesday.
