I am trying to create a circular Floor from GH to Revit and when I set a circle as a boundary the floor component does not work. However, when changing the geometry to a polygon it works perfectly. Does anyone have experience it?
Hi everybody,
I was trying to create a simple circular slab with Rhino Inside Revit. If I use the shape of a circle, the error attached to the message appears. If i use a poligon it works properly. Do you have some explanation? Can I do with circle in some way? Thank you in advance
Keep an eye out for the next RC 1.10 version (not the one highlighted), this will have a the fix. The Daily Build 1.11 has the fix but contains potentially unstable features and not suitable for production work. Feel free to test though.
