Probing results { 0,0,0}
Hello there! I’m trying to do a simple wind analysis from scratch. Everything seems to go well until I get to the probing part and I keep getting { 0,0,0} values as results so when I try Vector Display Ex, nothing shows. I have Rhino 8.21, Eddy 3D 0.4.15.3 and blueCFD 2020-1.
Is anyone having the same trouble? I can’t upload the rhino file because is too heavy but here is the we transfer link in case someone can help :slight_smile:
ANÁLISIS VIENTO.gh (19.0 KB)
Hi Keyla. I ran into this problem before. I dont know exactly what I did back then to solve this problem, but I recommend to check, if some of your probing points are inside a brep or in/on a surface. You can do that with the component “PointInBrep(s)”. Just filter the ones inside and continue with all the points outside. This helps with a lot of problems. LMK if that helped!
