Printing from 3D models still super buggy
This and worse happens constantly, simple or complex projects, it continues to create unnecessary time sinks for either cleanup, or using the 2D plan command, which comes with it’s own bugs and quirks.
Hi @rheinason,
We have fixed many issues related to vector output of viewports using the “Hidden” display mode in VisualARQ 2.3, which will be released on Wednesday (if we don’t find any major issue).
The visible white line between solid section hatches is one of the fixed issue.
Thanks,
Enric
Another bug that we’ve found is that the Hidden Display mode does not respect the difference between printed and display colors, and outputs display colors when printing. Even though the preview shows it correctly.
This issue should be also solved in VisualARQ 2.3.
If you want, send me a model where you see this issue so I can check if it’s fixed.
Thanks,
Enric
@rheinason The VisualARQ 2.3 version is already available to download. It fixes several bugs related to printing to vector output. You can see the full list here VisualARQ 2 - Version 2.3 released
Let us know if you find other issues. Thanks!
