Bug occurs on my Windows 10 I7 surface studio running Rhino 6 SR27 2020-6-24 Rhino 6, 6.27.20176.05001
I tend to make quick and dirty renders of my model files with dimension annotations to use with my assembly instructions and today i noted a bug. I typically use the “annotations” and “isocurves” options (adds a more tech drawing look to the render and makes certain details more defined)
So when you hit render you can not access the post effects screen till after the render completes. once complete you can select the tab and check a box, and if you are really quick a second box… once the first check box finishes rendering, the check boxes no longer have any effect on the image and i have to cancel the render and start over. there seems to be no refresh or other way to get it to process again. because of this behavior i had to try three times to check the box fast enough to get my finished picture. Is this a bug or am i missing something?
