I’m getting different contrasts in my frame on two different machines when using raytraced display mode. It’s like there is a post effect on the machine with the higher contrast. But this machine does not show the “Post Effects” panel in the viewport properties, it also doesn’t show the “Focal blur” panel. Is there somewhere you toggle the visibility of these panels? Are they connected to a missing plugin? Or any other ideas why the’re not showing up?
Both machines are running (7.9.21222.15001, 2021-08-10)
See attached examples in the normal Cycles raytraced mode.
Thanks
Oscar
