@nathanletwory
I just finished rendering large image that took me ca. 10 hrs.
Then I needed to adjust one thing and I wanted to fix it by rendering a patch of an image and overlap in in a graphic software.
The two problems I had were:
There were no object outlines on a RW image, they were on a full image
RW doesn’t offer saving which takes me back to rendering the full image
I don’t know why the extra parts aren’t showing. It is something that is not done by Rhino Render (Cycles), but rather by other parts of Rhino.
@johnc do you know if the RDK is responsible for showing the wireframes? I know I add the wireframe channel to the renderwindow when the render is started. Is there maybe some different handling going on for RenderInWindow?
This is a bug in Rhino, specifically in the RDK. When RenderWindow and RenderInWindow are run, the RDK does not produce the wireframe data for the post effects to use. It’s an oversight. I will file a bug and try to get it fixed. Sorry for the inconvenience and confusion.
