WIP7 does not display point clouds well because the points are too small. I made this screenshot in shaded mode.
Rhino6 has the same problem. I have to double cloud point size using Options command.
Hi Andrew - that is on purpose. A typical point cloud will have several thousand, if not several million, points. With clouds like that, you would probably notice that they display better (i.e. nicer) when the individual points are smaller.
As you have shown, if you don’t like the size, you can easily change it to the value you prefer.
I disagree. The point size should be measured in pixels. At present the point size is meaningless. If you believe that the cloud points should be smaller than separate points, make them smaller by changing their default size rather then by falsifying their real size.
TestPointCloudStyle
For world size points…
