Plugins do not work
Over here I received this message today when opening Rhino 6. Yesterday I installed Rhino 7 WIP.
Rhino 6 SR11 2018-12-14 (Rhino 6, 6.11.18348.17061, Git hash:master @ 600b621e607cf5226a968db60d7ac9230541b94d)
Testing C:\Program Files\Rhino WIP\Plug-ins\export_IGES.rhp (and 28 other assemblies) for compatibility…
Compatibility test failed in 11.98s
The plugins are not working on my Windows system as it is not supporting it. I have tried to install the plugins but it did not. My ssystem is having some issues of booting and I think that is why it is happening. I have to fix ERROR CODE 0XC0000428 to get the plugins installed.
@Gerard do you have Rhino WIP installed, too?
@rocky700 I’m not sure what you mean. Can you please send a screen shot of any errors you are seeing?
Yes Brian, the day before I installed V7 WIP for the first time.
After deinstalling V7 WIP, Rhino 6 doesn’t load RhinoScript.rhp. So it is not fine yet.
2019-01-30_12-34-29
Did you answer No in that dialog? It should load the plug-in then…
Yep it works fine again.
However I feel a little bit reluctant now to install V7 WIP again.
