Failed to load Rhinoscript plug-in message
I seem to recall others having this happen…
I answered No and restarted Rhino, no more message and Rhinoscript appears to be loaded.
Nothing changed since yesterday, except I updated the WIP. Probably related?
@brian, this sounds like installer related issue.
Hmm, just got it again - this time nothing was installed/updated in between the previous occurrence…
i used to have this issue a few weeks ago, always when one Rhino session was already running and starting 2nd one. It went away aftet installing a new daily build of V6…
To pile it up:
might be relevant.
What version of Rhino were you starting when you saw this message?
6.15
It starts happening over here as soon as I have WIP installed, and one Rhino 6 instance is running and when I try to start another Rhino 6 (no WIP running). Then the 2nd instance of Rhino 6 fails to load Rhinoscript. Sometimes it just works, but often fails like that. I think when WIP is removed, the problem goes away.
–jarek
Maybe RhinoWIP indeed plays a role. I have it installed but I don’t ever use it, I think.
:thinking:, which rhino is run when debugging a VS project?
This is annoying…
still happening, yes. This is the reason I don’t have WIP installed anymore, until this is solved.
From what I can tell, asking around here, this is the cleanup routine…
  1. Uninstall Rhino 6
  2. Uninstall Rhino 7
  3. Open Registry Editor (in the Windows start menu, type RegEdit, then press Enter)
  4. Browse to HKEY_LOCAL_MACHINE\Software\McNeel\Rhinoceros\6.0\
  5. Delete the Plug-ins folder
  6. Browse to HKEY_CURENT_USER\Software\McNeel\Rhinoceros\6.0\
  7. Delete the Plug-ins folder
Now, reinstall Rhino 6 (and the 7 WIP if you want), and it should all be cleaned up.
I’m sorry it’s so tedious. And I do not know if there is a better or more automatic way in the works.
There has to be a better explanation what is causing this.
  • Why do I need to uninstall Rhino6?
Seeing registry entry just for Rhino6 is used, a question arrises:
  • Why do Rhino6 and RhinoWIP use the same Registry entries? Same AppData/ProgramData folders?
That should be fairly easy to do with CMD/PS.
Can the installer run in silent mode? Any tutorials?
@echo off
rem 1. Uninstall Rhino 6
cd C:\Users\peychev\Downloads\
start rhino_en-us_6.16.19169.11231.exe -uninstall -quiet -norestart
rem 2. Uninstall Rhino 7
cls
echo wait some time for the uninstall to finish
pause
cls
rem 3. Open Registry Editor (in the Windows start menu, type RegEdit, then press Enter)
rem 3a. Browse to HKEY_LOCAL_MACHINE\Software\McNeel\Rhinoceros\6.0\
rem 3b. Delete the Plug-ins folder
reg delete HKEY_LOCAL_MACHINE\Software\McNeel\Rhinoceros\6.0\Plug-ins\ /f
rem 3c. Browse to HKEY_CURENT_USER\Software\McNeel\Rhinoceros\6.0\
rem 3d. Delete the Plug-ins folder
reg delete HKEY_CURENT_USER\Software\McNeel\Rhinoceros\6.0\Plug-ins\ /f
reg delete HKEY_CURENT_USER\Software\McNeel\Rhinoceros\5.0\ /f
echo Done!
pause
This week I installed win10 pro in a new pc, the first program I installed was rhino 6 then vray next plugin, and later Rhino V5 with T-Splines + VSR.
Version 6 SR16
(6.16.19169.11231, 6/18/2019)
Version 5 SR14 64-bit
(5.14.522.8390, 5/22/2017)
I don’t remember upgrading anything yet, I didn’t install wip 7 either, but I received the same message today…
Last week I received the same exact message and I though that having multiple versions of rhino ( v5,v6 and wip7) could be the problem, or letting rhino install SR candidates, but now I’m a bit lost.
What should I do?
How can I prevent this happening again?
Should I paste this in CMD?
If you ask this question, I’d say don’t use the script.
FYI I followed this steps from Pascal’s comment.
  2. Open Registry Editor (in the Windows start menu, type RegEdit, then press Enter)
  3. Browse to HKEY_LOCAL_MACHINE\Software\McNeel\Rhinoceros\6.0\
  4. Delete the Plug-ins folder
  5. Browse to HKEY_CURENT_USER\Software\McNeel\Rhinoceros\6.0\
  6. Delete the Plug-ins folder
  7. reinstall Rhino 6
The error message disappeard.
Thanks,
Joaquín
Hi, I just had the same issue and after searching in the forum and getting here, I solved it in a similar way:
Close Rhino 6
Run WiseRegistryCleaner ( free)
Repair the Rhino installation from the Windows Programs and Features
Done.
-I’m not sure about what causes it but a guess could be opening several rhino instances with heavy models at the same time. at least that was what I was doing when I saw the error.
