We are currently developing an in-house plugin with Rhino Common for one of our projects. The plugin is meant to create a large number of polysurfaces, by copying, trimming, splitting etc. a large number of surfaces… We had developed a Python script before, which runs fine (albeit slow). When re-coding everything in Rhino Common, the plugin works fine (and is much, much faster). However, when processing a large number of items, Rhino crashes on a regular basis. I cannot really find out what is causing the crash…
What I did notice: Let’s say I have 100 items to process, I can run the plug-in fine by processing, let’s say, 20 items at once and executing the plug in five times in a row. When I select all 100 items at once, it crashes about half way through. Perhaps it’s some kind of memory issue (as I mentioned, the plug in does copy, trim, join a large number of surface/polysurfaces in rhino common, before creating the final rhino run-time objects).
Would anyone be able to direct me as to what is causing the crash and how to avoid it? Thanks.
