Rhino keeps crashing whitout any save. A memory allocation failed and rhino will close
rhino_issue
ENven after restarting, even turn off and on the computer, rhino wont work anay more. It let me do whatever I want, but as soon as I save, it crash giving me the erro in the picture.
On rhin its says that I have use 460MB and that there is still 13446MB free… so I dont undersand.
What could I do? It comes from RHino, not my computer as I have plenty of free memory.
Hi Cam,
This could indicate a hardware failure, where some of your RAM might be damaged.
A quick google provides many options to check this.
https://www.google.nl/search?q=test+RAM+on+windows
Here is a not so complicated way to test it:
Please report back what you find
-Willem
Do you have any third-party plug-ins installed?
If so, you might try disabling them to see if the crashing stops.
Thank you very much @John_Brock and @Willem, sorry I couldn’t respond before. It is still crashing so I can not save any work, the only thing I can sve is the stl, but not .3dm files.
I checked and my computer is fine, thank you for the link. I think its Something about plug-in as it started this Strange behavior right after I accept to install a plug-in (as otherwise the first time when I clicked on no it did not download my stl. in rhino). I am still stuck, as I dont know any thing about plug in, which one it was etc.
@cam If you paste the result of the Rhino command _SystemInfo here we’ll be able to tell you.
Hi Cam - start Rhino and in Options > Plug-ins, filter the view for ‘Plug-ins that do not ship with Rhino’ .
Disable these (probably only one or two) and try saving - if it works, re-enable one or two plug-ins at a time and try again until, hopefully, at some point it will crash and you’ll have an idea which plug-in is responsible…
Thank you very much @nathanletwory and @pascal for your help!
When I use _SystemInfo command I obtain:
Rhino 6 SR6 2018-6-26 (Rhino 6, 6.6.18177.16151, Git hash:master @ abeff9e9af62a0e02a9eb52efa77e179a682f2c7)
Licence type: Évaluation, build 2018-06-26
License details: Cloud Zoo. In use by: Camille Montalcini ()
Expires on: 2018-07-30
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: LAPTOP-TJID61TE
GeForce GTX 1050 Ti/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 388.16)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-30-2017
Driver Version: 23.21.13.8816
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.6.18177.16151
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.6.18177.16151
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.6.18177.16151
C:\Program Files\Rhino 6\Plug-ins\RhinoResurf\RhinoResurf_r6.rhp “RhinoResurf”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.6.18177.16151
ALso when I check the plug-in in rhino as suggested, I have :
RhinoResurf is a plug-in which I neededseveral weeks ago, so it can not be this one.
Would you have any idea of which one I should delete (and how)? I was not able to find ‘‘Plug-ins that do not ship with Rhino’’…
Thank you very much for your help!!
Hi Cam - see Options > Plug-ins page
I would disable RhinoResurf and see if that makes a diffference.
Hi @pascal!
Thank you for your answer, for now its working, but it seems to me that it can not come from this as I did not had any problem with rhino when downloading and during the next few weeks. Also, suddenly after accepting downloading a plusg-in I had the almost Always since the error, but I dont know which plug-in it was.
In any case thank you very much for all your help!!
Wishing you a nice evening
In any case
