once again I am despairing with Rhino’s performance. This time I am trying to add some dimensions to a layout and object snapping is so slow that it becomes virtually unusable.
I am using VisualArq’s 2D plan view feature for documentation so the plan is mostly lines and hatches. When I hide the plan view snapping works but then I don’t have a plan to put dimensions on
I am running Rhino 7/VisualArq under Windows 10 on a 2019 MacBook Pro, I guess it’s probably not the best machine for the task; but I am thinking there has to be a way to make it work so that at least I can do simple documentation!
I’ll attach system info and you can view the file here Dropbox - PVZH VisualArq.3dm - Simplify your life
Thank you for any help!
Rhino 7 SR22 2022-9-12 (Rhino 7, 7.22.22255.05001, Git hash:master @ 196b1bc7dd093321e28dcc7a2bb8709a9bebe12d)
License type: Kommerziell, build 2022-09-12
License details: Cloud ZooWindows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: AMD Radeon Pro 5500M (AMD) Memory: 4GB, Driver date: 11-11-2021 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 20.45.40.15 27.20.14540.15002
> Integrated accelerated graphics device with 7 adapter port(s)
- Secondary monitor attached to adapter port 1OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU’s maximum)Anti-alias mode: 4x
Mip Map Filtering: Linear
Anisotropic Filtering Mode: HighVendor Name: ATI Technologies Inc.
Render version: 4.6
Shading Language: 4.60
Driver Date: 11-11-2021
Driver Version: 27.20.14540.15002
Z-Buffer depth: 24 bits
Total Video Memory: 4 GBRhino plugins that do not ship with Rhino
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”Rhino plugins that ship with Rhino
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.22.22255.5001
C:\Users\info\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
