Just a follow up, I tried the workaround of printing the A3 layout at A1 (thereby forcing Rhino to increase the print resolution) by scaling the print to fit, but Rhino just refuses to scale it up (despite the settings indicating that it’s being scaled). See attached…
not sure if this better, the perspective in rendered display mode still looks a little jagged when zoomed right in, file attached Counter Layout .pdf (2.6 MB)
2- After I closed the file, a lot of my view modes had changed and Rhino started to work a little slower. I had to re-import my preferences to get it back working again.
Yours does not give a choice between “Viewport”, “Extents” and “Window”, and as you can see the latter gives a similar result to your version, i.e. the scale is set as “Scaled to Fit”, yet the picture does not extent to the full page size.
It appears that the “Window” choice asks for a window to be set around your objects, meaning that the printing resolution will be applied to the entire window setting. This could explain the bad resolution of your pdf, when for some reason a large window has been set around your objects.
Max.
Edit: I see that your 1:1 scale picture shows the objects filling the entire sheet, which sort of dispels my theory. But the missing input fields still remain mysterious…
Hi again @Seychellian, here you have your file “fixed”
There were a few problems with your file. Your drawing was very far away from the origin, and if you use _ZoomExtend you could check that there were curves very far from your model. There were also 2 bad objects and many duplicated ones.
I moved your model to W0,0,0 and deleted all curves that shouldn’t be there. There were also curves in Layout very far from the page, did you copy-paste from one file to another?
The problem is that when you move the model, your detail views are no longer synchronized, so you have tomanually update all details views one by one. I did a few of then but you will have to finish them and check everything because I eyeballed the ones I did. Counter_jespizua.3dm (17.7 MB)
And here is the pdf. As I told you, there are detail views that are not in sync… Counter_jespizua.pdf (11.8 MB)
Edit: In my home computer I have to wait a few seconds until Preview will show a sharp image…
Thanks for the files. Your PDF print is indeed more crisp when I open it, however I am unable to reproduce that quality when I print from your 3dm file. Could you do a screengrab of your print settings for me to cross check?
These are my settings and my output (on your 3dm file) …
Not sure, this is a company computer so I assume that it’s a commercial license also. Is it a free upgrade to 5.4? I thought all versions of Rhino for Mac were still WIP.
