Problem with printing rendered layout
Probably someone could help me…
I want to print a layout with a detail from a model in rendered view mode (which worked with this projekt with no problems before) - but suddenly the pdf print output only shows the dimension lines an the text which were drawn in the layout window.
If i switch the view mode of the detail to grid view - the pdf prints the plan view.
Also the shaded mode does not work.
Does anyone know what i can change to solve this problem?
Thanks
Hello - Please run the SystemInfo command in Rhino and copy/paste the results here.
Rhino 7 SR5 2021-4-6 (Rhino 7, 7.5.21096.11001, Git hash:master @ 4cd1d638a2f2d3bb193441ecfc1e54559d092807)
License type: Kommerziell, Build 2021-04-06
License details: Cloud Zoo
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro K4200 (NVidia) Memory: 4GB, Driver date: 6-21-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 451.48
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-21-2020
Driver Version: 27.21.14.5148
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\admin\AppData\Roaming\Grasshopper\Libraries\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.5.21096.11001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.5.21096.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.5.21096.11001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.5.21096.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.5.21096.11001
Hello Pascal,
the problem must be somewhere in the settings of rhino - because if i delet the setup file : “settings-Scheme__Default.xml” and start rhino again - the layout / details can be printed as render view.
The only problem by this solution ist that i loose all the settings …
Also funny is that if i print the layout nothing is shown on the print (except the dimension lines and the text head that i had drawn directly in the layout view) - but if i look at the layer structure in the pdf - all the layers are named (but they are empty)…
Hi @aazt,
Can you attach the 3dm file and the settings file here or send it to me privately through Rhino - Upload to Support.
Please give exact steps for how to reproduce the issue.
-David
@aazt,
There was an issue downloading the file due to “strange” characters in the file name. Can you change the filename by removing characters like åäö and send it in again?
Thanks,
-David
Hello David,
did the file work now?
Thany you,
Manuel
Yes, thank you.
I am currently looking into the issue. I can reproduce a crash, actually, so I’m focusing on that. I’ll let you know what I find.
-David
Hi @aazt,
Thanks for reporting this issue. I’ve fixed the problem, and it will show up in a Rhino 7 service release candidate in about a month, and a service release in about two months.
If you want the fix as soon as possible I can give you a link to a fresh Rhino 7 build when it’s done. On the other hand, if you have worked around the problem for now, you are free to wait for the fix to appear in a service release.
-David
Hello David,
thank you very much for solving the problem!
Due to the fact that i have not solved the problem for my project or worked around jet - and the project is running - i would be very grateful if you could give me a link to … the solution …
Do you know how long it takes until you could sende me the link?
Thank you
Greetings Manuel
Hi @aazt,
Here you go: https://files.mcneel.com/dujour/exe/20210414/rhino_en-us_7.7.21104.19001.exe
Does it work for you with the Rhino build?
-David
Hello David,
works perfect!
Thank you for your help!
Hello David,
whats funny with the new version is:
if i want to print the layout and i choose another resolution than 600dpi (for example 1400dpi) - i get a blurrier / worser print as with 600dpi… Also the size of the pdf file is smaller by printing with 1400dpi than with 600dpi!
Another point that i noticed is that the performance is much slower than the old version…
Greetings Manuel
Hi @aazt,
Yes, I can see the DPI issue. This issue has been in Rhino at least since Rhino 7.5, so it is not only happening in the new version that I linked. I made a YouTrack item for the bug: https://mcneel.myjetbrains.com/youtrack/issue/RH-63844.
When you say it’s slower now, do you mean that Printing is slower? Or viewport manipulation? In the default settings case there was a bug where skylight shadows weren’t being printed. After my fix, they are included in the print, and this will make the print take longer to finish.
-David
hello! i have a similar problem but in my case the layout is in a different position when i print to pdf…it moves a bit
This is the information of my system, if you could help me I would really appreciate it!
Rhino 7 SR21 2022-7-27 (Rhino 7, 7.21.22208.13001, Git hash:master @ c31aea87137a5d0de449338a7ef6856f49dd4797)
License type: Educacional, build 2022-07-27
Windows 10 (10.0.19043 SR0.0) or greater (Physical RAM: 12Gb)
Primary display: Intel(R) HD Graphics 620 (Intel) Memory: 1GB, Driver date: 2-28-2018 (M-D-Y).
Primary OpenGL: NVIDIA GeForce 940MX (NVidia) Memory: 4GB, Driver date: 9-23-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.19
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 9-23-2021
Driver Version: 30.0.14.7219
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\export_PDF.rhp “PDF Export” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.21.22208.13001
C:\Users\admin\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
