Since I have phased out my drafting to my staff, this issue seldom comes up with me, but seriously, this has been haunting me forever.
Although, I like the elements of bringing in a PDF file & having Rhino Read it, is it too hard to implement a script or Macro to either trace the text, or actually bring it in as an object, why is it so buggy?
Maybe I’m doing something wrong, but I’ve tried bringing the PDF in, in many ways, but it always gives me like a bastardized copy of the PDF itself.
I understand the preference is for the issue to be resolved. I opended the PDF in Inkscape, then resaved as a PDF. This opens in Rhino with a similar font as the original, but there are some differences.
Curiously, the original PDF does not display the missing font dialog even though it is checked off in the Rhino import dialog. However, the file saved from Inkscape shows the missing font dialog.
There is some translating into Hindi going on, and some missing / replaced letters.
I’ve put this on the list as RH-98826 File IO: PDF Import Errors
I can’t trace that file, I can open up a clean Rhino file, repaste it and see what the system info is, but i just pulled this one from one of my master template files. Let me know if it helps.
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1650 SUPER (NVidia) Memory: 4GB, Driver date: 7-2-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 610.74
Accelerated graphics device with 4 adapter port(s)
Windows Main Display attached to adapter port #0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-2-2026
Driver Version: 32.0.16.1074
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\kapuk\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\RhinoGPT\1.0.9\RhinoGPT.rhp “RhinoGPT” 1.0.0.0
Is it automatic, & was the string of code above helpful? Did you try it with this particular file? I haven’t imported any PDFs since any of the updates. What was causing the issue?
