Attached is a screen shot showing the result of a pdf import at 1 drawing unit =1 Rhino unit (the drawing sheet is 36" x 48".) Why is the text so huge?
Thanks,
Dennis
… Also, please run the Rhino SystemInfo command and copy-paste the result here.
I reset them all to 1. Still no luck.
Rhino 6 SR31 2020-11-10 (Rhino 6, 6.31.20315.17001, Git hash:master @ ff08c426b1ef7d3a1c50a01e5e87220a68a9f815)
License type: Commercial, build 2020-11-10
License details: Cloud Zoo. In use by: Dennis ()
Windows 10.0 SR0.0 or greater (Physical RAM: 64Gb)
Machine name: GOBOXX-G2521-04
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA Quadro RTX 3000 (NVidia) Memory: 6GB, Driver date: 4-8-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 442.94
Secondary graphics devices.
Intel® UHD Graphics (Intel) Memory: 1GB, Driver date: 1-22-2020 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-8-2020
Driver Version: 26.21.14.4294
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.31.20315.17001
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.31.20315.17001
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\Import_PDF.rhp “PDFReader”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.31.20315.17001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.31.20315.17001
Hi - thanks for that. It looks like you are up-to-date with the Rhino version. We fixed a similar issue a while back but there is clearly something still going on. Could you post that pdf file?
It’s confidential. Can I send it to you privately?
Hello - please send to tech@mcneel.com, with a link back to this topic in your comments.
@dmoyes - your file opens as expected in both V6 and V7, here. Are you Opening or Importing?
Also, I do not see the font you show in your image - only Arial.
I have a similar issue. Import a PDF of a drawing which was probably originally created in AutoCAD. It displays properly in Adobe Acrobat. When imported into Rhino there are 39 layers. The non-text portions import correctly. The text comes in very large and aligned around the origin.
Any suggestions?
Rhino 7 SR8 2021-6-17 (Rhino 7, 7.8.21168.01001, Git hash:master @ 401162001ce142638467ff15f97e7bc9e02b017a)
License type: Commercial, build 2021-06-17
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 5-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.59
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 5-6-2021
Driver Version: 27.21.14.6259
Total Video Memory: 11 GB
C:\Program Files\Orca3D V2\Orca3D.rhp “Orca3D” 2.0.21.0
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.2\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.2.0
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.8.21168.1001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.8.21168.1001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.8.21168.1001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\Import_PDF.rhp “PDFReader”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.8.21168.1001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.8.21168.1001
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.21.831\SectionTools.rhp “SectionTools”
Hi David - I guess it would be best if we could have that pdf file - can you send it to tech@mcneel.com, with a link back here in your comments?
