Paste + nudge gives me a windows error sound and no nudging
This worked in previous versions and now doesn’t seem to work.
I use nudge quite often and have it also set up to be used with the arrow keys like so:
Now what I often do is making a copy by selecting something, then Ctrl+C to copy and Ctrl+V to paste it again and then immediately nudge it to move it a specific distance without having to click or type dimensions.
In rhino Beta, after I paste and try to nudge it my computer makes a windows error sound and it doesn’t nudge the object. If I rotate the view after pasting and then nudge it seems to work, but that seems quite cumbersome. :slight_smile:
Does clicking in the viewport after the paste make nudge work?
By left clicking I lose my selection? Right clicking to rotate the view solves it, but again, that seems like an unnecessary and cumbersome extra step :slight_smile:
Weirdly enough, when I try it today it’s not giving me the error sound and seems to work as expected. :confused:
Left‑clicking the viewport title or tab does not clear the selection.
Can we stop suggesting clicking as a solution to something that should work without having to click? :see_no_evil_monkey: My whole point was that it’s cumbersome to have to click to make it work.
Anyway. Even though I was testing quite a bit yesterday and kept on getting the windows error I haven’t had the same issue happening again today so perhaps there was something else going on.
Clicking isn’t being suggested as a solution - it is a diagnostic step to refine the scope of the problem in order to identify the root cause.
Right, I guess I could have responded a bit less harsh. In my original post I mentioned that it works after rotating the view, meaning clicking solves it. Perhaps that wasn’t clear from my side.
I have exactly the same problem, please fix it or tell me how to do it on my side
RH-97257 is fixed in Rhino BETA
Rino 9.0.26237.15343, 2026-08-25
Windows 11
Doesn’t fixed
Don’t work
The error sound can be heard on the recording.
RH-98161 Nudge stops working
Why? It was very convenient for modeling.
Right. That’s why it’s on the list to be fixed.
RH-98161 is fixed in Rhino BETA
