Bug report : Nudge works only one time
A small issue, the Nudge key works only one time & stops responding, had to rotate the view for it to do one more Nudge, and then on & on ..
G.
This has been reported eariler by one or two users, but it appears to be working here in the latest public Beta. Can you run SystemInfo in the Beta and post the results here? What are your settings for Nudge? Arrow keys directly or Alt+Arrow keys?
Kind of similar strange behavior with the Tab + Shift key combination (for direction locking). Sometimes it works, then stops working. I press Tab 2 times without Shift key, then works again :thinking:
As for Nudge, it works as expected so far
System Info:
Rhino 9 SR0 2026-7-14 (Rhino 9 BETA, 9.0.26195.12303, Git hash:master @ e65c4e97d90a610a755e1fa38d13856483719a8c)
License type: Not For Resale Lab, build 2026-07-14
License details: Cloud Zoo
Expires on: 2026-08-28
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 10.0.2
Non-hybrid graphics configuration using OpenGL
Primary display: NVIDIA GeForce RTX 4080 Laptop GPU (NVidia) Memory: 12GB, Driver date: 6-11-2026 (M-D-Y). OpenGL(4.6.0 NVIDIA 610.62)
Integrated accelerated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 4080 Laptop GPU (NVidia) Memory: 12GB, Driver date: 6-11-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 610.62
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 1-18-2024 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • There are no monitors attached to this device.
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-11-2026
Driver Version: 32.0.16.1062
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Users\gubar\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Users\gubar\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Users\gubar\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\Corgi\0.8.6\net7.0\Corgi.rhp “Corgi” 0.8.6.0
C:\Users\gubar\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\Terra\1.2.50\Terra.rhp “Terra” 1.2.50.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Import_PDF.rhp “PDFReader”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Mostly when using ctrl+alt+arrow, this happens on both work & home Pc.
here is my Home pc sysinfo:
License type: Commercial, build 2026-07-14
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 10.0.2
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce GTX 770 (NVidia) Memory: 4GB, Driver date: 6-10-2024 (M-D-Y). DirectX(11)
Accelerated graphics device with 4 adapter port(s)
  • Secondary monitor attached to adapter port #0
  • Windows Main Display attached to adapter port #1
Intel(R) HD Graphics 4600 (Intel) Memory: 1GB, Driver date: 3-8-2017 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
  • There are no monitors attached to this device!
DirectX Settings
Safe mode: Off
OK, I don’t know if it will help anything, but I would maybe update your video drivers, the NVidia one you have is almost two years old and the Intel one is nine years old…
Tnx’ will do, BUT thats my home pc, wich, yes kindofold, here is my workpc sysinfo, a newer pc that have the same issue.
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 10.0.2
Primary display: NVIDIA GeForce RTX 3060 (NVidia) Memory: 8GB, Driver date: 12-2-2025 (M-D-Y). DirectX(11)
  • Windows Main Display attached to adapter port #0
  • Secondary monitor attached to adapter port #1
None found.
DirectX Settings
Safe mode: Off
C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
that one’s on the list as:
RH-97014 Tab constraint is half broken
RH-97014 is fixed in Rhino BETA
RH-97257 is fixed in Rhino BETA
