Parametric curve form to surface
Hello
It is a parametric 3D form that, by changing 2 sliders, new forms are formed.
I want to convert lines to surfaces. But by changing the sliders, the surfaces are damaged.
An algorithm is needed, so that the surfaces remain as the sliders change.
Please install the required plugin (bengesht). And then check the file.
Thankful
bengesht_0.gha (326 KB)
Curve to surface.gh (8.3 KB)
curve-moqarnas.gh (20.9 KB)
This is quite an interesting shape.
wow
Thank you very much for your great help. It has been great. I should say that it is possible to do the same about this form? (orange lines)
Need to check the curves
Can you check those curves and convert them into surfaces if possible?
curve-moqarnas.gh (15.4 KB)
This seems very similar to this question
and I make tools in Nautilus plugin
PolylineToArches.gh (8.9 KB)
PolylineToArches2.gh (6.0 KB)
PolylineToArches3.gh (11.2 KB)
I don’t get it. It is the same file I gave you.
Yes, it is the same file
But there are other lines in this file that need to be surfaced. These lines are inside the form. That’s why I grouped them in Grasshopper for you to notice.
curve-moqarnas Edited V1.gh (47.6 KB)
:grin:
wow!!
so cool
