Paperspace print of my work
David Cockey was kind enough to help me earlier this wekk when I was importing some 3D DWG files. Its taken me a few days but I’ve now got a proposal to present. Except, I can’t get to grips with the paper space… There’s a pun there as I wanted the grips so I could resize before locking. The POINTS command just seems to put points in the detail view instead of the grips I am looking for.
Any pointers please before the weekend ? Have a good one.
Hi Terry,
If you’re in Layout view, you can usually just click on the perimeter border of the detail you want to resize and it should turn from black to pale yellow and corner points as well as edge mid points should show up.
You can then select one or more points and either Move them or manually translate them with the Gumball trinket (might be disabled).
