I am using a Nvidia p4000 [8GB] in a laptop with two attached monitors [both FlexScan S2133 in Portrait Mode; 1200 x 1600 resolution] . All of the rendering work is done in Rhino 7 Raytrace Mode with the UI spanning both monitors. Using the mm scale template a final render might be 600x600 72 DPI and Final quality. Often when I am modeling I will set one or more view ports to Raytrace Mode so as to get a better feel as to how the design is looking [and move it around] e.g. it is looking horrible > scrap it.
Given that the GPU is technologically older and not very powerful am I better off using the Nvidia Denoiser or Intel Denoiser or perhaps simply select both in Tools>Options>Post Effects and let the system / Rhino choose [given this is possible ?] the optimal one.
ok. Given that you have a newer / more powerful Nvidia GPU, does the Nvidia Denoiser seem to work better? Or are their to many other variables to make an “in most cases” statement.
Personally I use the Intel Denoiser even though I could use the Nvidia one. The results are identical in most cases in my experience and this leaves the Nvidia card free to just do the raytracing. The Intel denoiser will work on the CPU and despite the name is not only for Intel chips.
I understand that they are separate right now, but IMO the technology is so important that the intel CPU version (that works on all systems) should be integrated and ON by default. It saves both time and a lot of power too, and will show off the power of the integrated renderer (cycles) even better.
Now users have to first learn about it, then install it, reboot and then turn it on for every single file (or the default template if they are so advanced that they actually do so…)
So please consider.
At least consider moving it from document setting and over to system setting.
IMO the nVidia one can be installed on demand, and then chosen on a higher level.
I said the same thing as you during development. If memory serves, they had to be separate user installs due to the licensing requirements of these denoiser plugins. I’m not sure if that has changed but @andy may.
I am draw back to this tread having [in more cases that I would like to admit] needlessly increased the render time by forgetting to enable the Denoiser and for inexplicable reasons did not proceed with the work flow that Holo suggests with regard to the default temples. Maybe to help the sometimes absentminded me(s), and to inform others, a help tool message could trigger that would briefly describe the Denoiser App and perhaps link to the Rhino help file with the specifics e.g. Nvidia and Intel versions etc. And I am finally going to proceed as Holo suggests.
Thank you,
Andy
p.s. The message could also have a “so not show again” checkbox
