when installing the plugin, it doesn’t show in Revit, and when I checked the plugin file for Revit it didn’t have rhino inside revit addin in it,
and when i tried to manually install the folder and the addin, it didnt also work
Hi AbuBakr helmy,
This sounds like a plugin conflict but will need more details.
What version of Revit & Rhino are you working with? Ideally everything is up to date with both.
HI !
Revit 2023, unfortunately i cant update the Revit version due to a technical issue,
and i’ve tried it with rhino 7 and rhino 8
Min version is 2023.1
ok, thanks for your time!!
